1310
Summary Row or Set ReadOnly property to false to a row
I have a grid which the last row must be a Sum of each column. I have done in my viewModel all the calculations and I have added the row. As the grid is editable I come across with the problem of this last row. It must be read-only.
The rows are dynamically charged from my viewModel.
Another solution I have found is the SummaryRow, but the problem is that I am not able to disable the littel button on the columns and to show directly the Sum of the columns when the grid is loaded.
By the way... how can I modify the template of the SUM= XXX ? I want to display only the numbers.
Thank you
