1060
Custom Tick values in XamDateTimeSlider
I am using "XamDateTimeSlider" in my Silverlight MVVM application. We have list of reports created on different dates so we need to give Slider controls from where user can select Date of report which he want to see.
We don't need the DAY, Month etc. frequency as Creation Date may be like this
1/1/2010      3/2/2010    3/5/2010       2/1/2011       2/2/2011
etc. so I want to mark the Tick only on these dates and user can slide to these dates tick only. Obviously I will bind MIN & MAX values but how can I bind the TICKMARKs property to a LIST<DateTime> property of my view model?
Any idea to accomplish this, please???
  • 435
      The solution for this is two fold, I've created a small example that should be able to get you headed in the right direction.  Basically, we need to create our own TickMarks, and in there we can override the TickMarksCollection and use our own values.  Also we tell the thumb that is on the Slider that it must always snap to the tick marks.  Just a note, the visual studio designer may complain about using a custom tick mark type, however, it will compile and run just fine.
    Hope this helps you get what you were looking for, if not let me know and I'll see if I can find something else!
    Thanks!
    Rich
    Here is the Xaml:
            <ig:XamDateTimeSlider Name="slider1" MinValue="1/1/2010" MaxValue="2/2/2011">
                <ig:XamDateTimeSlider.Thumb>
                    <ig:XamSliderDateTimeThumb IsSnapToTickEnabled="True"/>
                </ig:XamDateTimeSlider.Thumb>
                <ig:XamDateTimeSlider.TickMarks>
                    <local:CustomTickMarks>
                    </local:CustomTickMarks>
                </ig:XamDateTimeSlider.TickMarks>
            </ig:XamDateTimeSlider>
    And here is my class:
        public class CustomTickMarksDateTimeSliderTickMarks
            public CustomTickMarks()
                this.IncludeSliderEnds = true;
            public override System.Collections.ObjectModel.ObservableCollection<DateTime> TickMarksValues
                get
                    return new System.Collections.ObjectModel.ObservableCollection<DateTime>() {
                        new DateTime(2010, 1, 1),
                        new DateTime(2010, 3, 2),
                        new DateTime(2010, 3, 5),
                        new DateTime(2011, 2, 1),
                        new DateTime(2011, 2, 2) };
