- What are the known issues and limitations for the new 11.2 XamGridExcelExporter?
- Is there a size or record/column limit on your end? Or should we be able to fully utilize excel limitations for each format 2003/2007/2010, etc.
- What is the recommended approach or method to handle large data sets? In several of my scenarios I have 100k + Records with 80-100+ columns. Are there any recommended setups for Workbooks, WorkSheets, Export, or anything else that are required or recommended for larger exports? The largest export samples I saw was 10,000, are there other larger tests that have been carried out? I dont have a problem with anything under 50,000.
- In some cases I am getting out of memory exceptions and xml document generation exceptions using both the writer and the new XamGridExcelExporter. Are there known limitations here from infragistics or are we only limited by memory and excel?
Thanks again
Hello yumi,
After some research the functionality that you are looking for has been determined to be a new product idea. I have sent your product idea directly to our product management team. Our product team chooses new product ideas for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested ideas, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your idea is chosen for development, you will be notified at that time. Your reference number for this product idea is PI12050110.
If you would like to follow up on your product idea at a later point, you may contact Developer Support management via email. Please include the reference number of your product idea in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
Hey Yanko Nikolov,
I am also facing the same problem "out of memory exception" when Export to Excel from my silverlight application.
The data around 1 millions row that i have to export into excel. If you have any solution then revert me back.
Thnaks in advance
Hello pidong,
I have created a support ticket for you with CAS-88695-048PRD in order to link the development issue to it so that you are automatically updated when a Service Release containing this fix is available for download.
Please include me in the updates. We're going to production at the end of the month and this is the issue that's keeping us now.
Even though the grid filters have reduced the number of records to even a single row, the out of memory exception still shows up as if it's still basing it on the original data set.
Hello donschaberg,
I have logged this behavior with our developers in our tracking system, with an issue ID of 104531. I have also created a support ticket on your behalf with number CAS-86353-XZYQ7T in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
