425
How can I select a row by right click?
I am using contextMenu in XamGrid. But I found if I right click at another row other than the selected row, I could not get the correct contextMenu.
So I would like to select the row when I right click a row. Is there any way to do it?
  • 425
    Verified Answer
    I have solved it myself.
    private void DataGrid_MouseRightButtonDown(object sender, MouseButtonEventArgs e)
                IEnumerable<UIElement> elementsUnderMouse = VisualTreeHelper.FindElementsInHostCoordinates(e.GetPosition(null), this);
                CellControl cellControl = elementsUnderMouse
                    .Where(uie => uie is CellControl)
                    .Cast<CellControl>()
                    .FirstOrDefault();
                if (cellControl != null && !DataGrid.SelectionSettings.SelectedRows.Contains(cellControl.Cell.Row))
    DataGrid.SelectionSettings.SelectedRows.Clear();
                    var selection = new SelectedRowsCollection();
                    foreach (var row in DataGrid.Rows)
                       List<object> items=new List<object> { cellControl.Cell.Row.Data } ;
                        if ( items.Contains(row.Data))
                            selection.Add(row);
                    DataGrid.SelectionSettings.SelectedRows.AddRange(selection);
                    DataGrid.ActiveCell = cellControl.Cell;
