900
XAMGridrid GroupByRow
After Grouping Silverlight XAMGrid by one column, While using xamGrid GroupByrow (by 1 column), for the  second 2nd Group, the Control property is always null. I am using following code to change focus from Hour textbox to minute textbox once 2 digits are entered in hours textbox.
Probem: Following is always null for 2nd Group in xamGrid GroupByrow. For 1st Group its returns controls on the Cell.
((Infragistics.Controls.Grids.Primitives.GroupByRow)(xamGrid.Rows[0])).Cells[5].Control
C# Code:
StackPanel sp = ((TUdgTargetTSSearchResults.Rows[currRow].Cells[5].Control) as ContentControl).Content as StackPanel;
                    XamNumericEditor item2 = sp.Children[2] as XamNumericEditor;
                    item2.Focus();
XAML:
<ig:TemplateColumn Key="MyTime" HeaderText="Idea Time" IsSummable="False" MinimumWidth="80" MaximumWidth="320" Width="Auto" IsSortable="False" IsGroupable="False" IsHideable="False">
                                        <ig:TemplateColumn.ItemTemplate>
                                            <DataTemplate>
                                                <StackPanel Orientation="Horizontal" Margin="3,5,3,5" DataContext="{Binding}" >
                                                    <sdk:DatePicker
                                                        x:Name="MyDate"
                                                        Grid.Row="0" Width="100"
                                                        Margin="3,0,10,0"
                                                        BorderBrush="DeepSkyBlue"
                                                        DisplayDate="{Binding Path=MyDate}"
                                                        SelectedDate="{Binding Path=IdeaDate, Mode=TwoWay}"
                                                        Visibility="Collapsed"
                                                        Loaded="MyDate_Loaded"
                                                    <ig:XamNumericEditor x:Name="MyHour" Width="30" Margin="0,0,5,0" Mask="{}{double:-2.0}" Value="{Binding MyHour, Mode=TwoWay, UpdateSourceTrigger=Explicit, NotifyOnValidationError=True, ValidatesOnDataErrors=True}" Tag="MyHour" GotFocus="XamNumericEditor_GotFocus" LostFocus="XamNumericEditor_LostFocus" KeyUp="MyHour_KeyUp" KeyDown="MyHour_KeyDown_1"/>
                                                    <ig:XamNumericEditor x:Name="MyMinute" Width="30" Margin="0,0,5,0" Mask="{}{double:-2.0}" Value="{Binding MyMinute, Mode=TwoWay, UpdateSourceTrigger=Explicit, NotifyOnValidationError=True, ValidatesOnDataErrors=True}" Tag="MyMinute" GotFocus="XamNumericEditor_GotFocus" LostFocus="XamNumericEditor_LostFocus" KeyUp="MyMinute_KeyUp" />
                                                    <ig:XamNumericEditor x:Name="MySecond" Width="30" Margin="0,0,5,0" Mask="{}{double:-2.0}" Value="{Binding MySecond, Mode=TwoWay, UpdateSourceTrigger=Explicit, NotifyOnValidationError=True, ValidatesOnDataErrors=True}" Tag="MySecond" GotFocus="XamNumericEditor_GotFocus" LostFocus="XamNumericEditor_LostFocus" KeyUp="MySecond_KeyUp" KeyDown="MySecond_KeyDown"/>
                                                </StackPanel>
                                            </DataTemplate>
                                        </ig:TemplateColumn.ItemTemplate>
