We are using Infragistic asp.net controls but WebDateChooser control in ASCX page, which works fine in IE8 browser but gives following error in IE9 browser :
General message:Faulting application name: iexplore.exe, version: 9.0.8112.16421, time stamp: 0x4d76255dFaulting module name: jscript9.dll, version: 9.0.8112.16441, time stamp: 0x4ee8124dException code: 0xc0000005Fault offset: 0x000c6645Faulting process id: 0x1668Faulting application start time: 0x01cd0860750fc5cbFaulting application path: C:\Program Files (x86)\Internet Explorer\iexplore.exeFaulting module path: C:\windows\SysWOW64\jscript9.dllReport Id: d0b1e1e1-7453-11e1-b268-00248c2a674a
Version using:
Asp.net 3.4, Visual studio 2008
Infragistics35.WebUI.Shared.v9.2, Version=9.2.20092.2155
Also it gives problem with UltraWebGrid control.
Can you please help us to solve the issue?
Hello Teller,
I am going to create a private case so I can send you the service release for v101. You can access the private case by going to the following link and logging in:
https://ko.infragistics.com/Membership/MySupport.aspx
Sincerely,Mike P.Developer Support EngineerInfragistics, Inc.www.infragistics.com
Hi Mike,
As per your suggestion I downloaded trial version of NetAdvantage_WebClient_Complete_20101 but still it’s not compatible in IE9 and we don't want to upgrade version v11 as it has no longer support for classic controls so it needs large code changes which is not affordable right now.
I suppose there are service releases available for ver10.1 for IE9 compatibility but I couldn’t find same on Infragistic site. Can you please guide me for same? or mail me service release?
Thanks!
I am following up to see if the information provided has resolved this matter.
Please let me know if I may be of further assistance with this matter.
For support of IE9 in the NetAdvantage for ASP.NET product I recommend that you upgrade to a later version such as versions v10.1 through v11.1 which support IE9. Please see the following blog post for further information about IE9 support:
http://community.infragistics.com/blogs/taz_abdeali/archive/2011/02/17/ie9-support-plans-for-asp-net-controls.aspx
http://community.infragistics.com/blogs/taz_abdeali/archive/2011/04/04/ie9-and-firefox-4-support.aspx
Please note that the classic controls such as the UltraWebGrid and WebDateChooser were retired with the release of v11.2 and if you would like to continue to use them the latest version with the classic controls is v11.1. Please see the following blog for further information:
http://community.infragistics.com/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx
Please let me know if you have any questions concerning this matter.
