3550
How to retreive the selected row.
I need to work on the row that the client selected
I dont manage to get the selected row.
I try to use Behaviors.Selection.SelectedRows[0]
Behaviors.Selection.SelectedRows seems to be empty, even if the user chooses a row.
this is the code.
What should I do?
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="WebForm2.aspx.cs" Inherits="WebApplication3.WebForm2" %>
<%@ Register assembly="Infragistics4.Web.v11.2, Version=11.2.20112.1019, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.GridControls" tagprefix="ig" %>
<%@ Register assembly="Infragistics4.Web.v11.2, Version=11.2.20112.1019, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI" tagprefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
</head>
<body>
    <form id="form1" runat="server">
    <ig:WebScriptManager ID="WebScriptManager1" runat="server">
    </ig:WebScriptManager>
    <div>
    </div>
    <ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px"   ViewStateMode="Enabled" EnableDataViewState="True">
                    <Behaviors>
                        <ig:RowSelectors>
                        </ig:RowSelectors>
                        <ig:Selection>
                        </ig:Selection>
                    </Behaviors>
                </ig:WebDataGrid>
    <asp:Button ID="Button1" runat="server" onclick="Button1_Click" Text="Button" />
    </form>
</body>
</html>
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using Infragistics.Web.UI.GridControls;
namespace WebApplication3
    public partial class WebForm2 : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
            List<string> ls = new List<string>();
            ls.Add("hello");
            WebDataGrid1.DataSource = ls;
            WebDataGrid1.DataBind();
        protected void Button1_Click(object sender, EventArgs e)
            GridRecord selectedRow = WebDataGrid1.Behaviors.Selection.SelectedRows[0];
