I m in need of setting Tooltip for every event title in XamTimeLine control.Pls have a look at the snapshot below
Thanks in advance.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
I have tried your sample code.It is throwing the following exception
System.Windows.Markup.XamlParseException: Set property '' threw an exception. [Line: 12 Position: 61] ---> System.NotSupportedException: Cannot set read-only property ''. at MS.Internal.XamlMemberInfo.SetValue(Object target, Object value) at MS.Internal.XamlManagedRuntimeRPInvokes.SetValue(XamlTypeToken inType, XamlQualifiedObject& inObj, XamlPropertyToken inProperty, XamlQualifiedObject& inValue) --- End of inner exception stack trace --- at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator) at XamTimelineTitleToolTip.MainPage.InitializeComponent() at XamTimelineTitleToolTip.MainPage..ctor()}
