Hello!
I use a DateColumn that is read only. I would like to remove the calendar icon because it is not necessary. Tell me how to implement it?
I know that the problem can be solved by setting the TextColumn, but it is interesting to use the DateColumn.
Thanks in advance.
Hi Sergey,
DateColumn uses DatePicker control from MS sdk as an editor. What you can do is to create a style in which you need to re-template the DatePicker control so the calendar button has its Visibility property set to collapsed. After creating the style you should set it to EditorStyle property of DateColumn.
Hope this helps,
