20
How to get the RowId in ClickEvent (Webgrid)
i am firing an automatic click event in infragistics webgrid by placing a button in first column of  a grid
unable to get the rowid by using the below function (But i need the same function as much as possible) Suggest me solution for the below issue (head is cracking for nearly 4 hrs)
function igtbl_colButtonClick(e, objID){
            //var grid = igtbl_getGridById("<%= UltrawebGrid1.ClientID %>");
            var grid   = igtbl_getGridById(objID).Rows;
            var id = grid.Rows;
            if (grid !=null){
            var row = grid.Rows.getRow(2);
              var Value=row.getCell(2).getValue();
              if ( (window.opener) && (window.opener.PopUpHandler) )
                window.opener.PopUpHandler(Value);
                window.close();
  • 820
    sample code to get the cell values and grid :-
    function igtbl_colButtonClick(gridID, cellID)
    var grid = igtbl_getGridById(gridID);
    var gridCell = igtbl_getCellById(cellID).getValue();
    var activeRow = igtbl_getActiveRow(gridID);
    var value = activeRow.getCellFromKey(
    "columnKey").getValue();
