I need the following configurationwith the DockManager :
When I want to move the "BLOC 4" or the "BLOC 5-1" I have the following exception :
Is that me doing wrong in my implementation or is that a bug ?
I attached a solution to show you how I do.
Regards.
Fabien.
Okay thanks for the reply, I'll wait.
Hello Fabien,
The ContentPane has a MinWidth and MaxWidth properties, still please have in mind that in some cases when you set the Location of the SplitPanes and the ContentPanes our XamDockManager control will place the panes ignoring the sizes that you set in order to fit them in the available space. Therefore I believe that the XamDockManager currently don’t support the layout that you require, so I submitted this design as new product idea with number PI12040077.
I'm back on my problem, I tried to specified a width for the DHC and the BLOC 4 to have a fake split pane but it seems that the size has a minimum value and my BLOC 4 seems to have a maximum value.
Is there a way to specify those values ?
If you would like to follow up on your product idea at a later point, you may contact Developer Support management via email. Please include the reference number of your product idea in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
