If you have a set of columns attached to GroupColumns. It seems as the XamGrid is not able to handle ColumnWidth set to ColumnWidth.Star properly.
In my example i have no width set anywhere and all columns have either Auto or Star set on their ColumnWidth, but for some reason i end up with a scrollbar in the grid that to me doesnt make sence.
See attached mock up example.
Questions :
1. If you resize the first column in the mock up. Shouldnt the increased width be "given" by the third column (the star one) and there shouldnt be a scrollbar present at all in the bottom or .. ?
2. If this is a bug can you register this in the support system so i get some feedback on this.
Øyvind
Hello ojohnsen,
The service release containing the fix for your issue is out, you can download it from: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
I'd be glad to receive a feedback on the outcome.
Hello Øyvind,
I have submitted this issue in our tracking system with developments issue of 110390. I will provide you with more details about this through support ticket CAS-89915-KTNW2S .
Please let me know if you have any questions on this matter.
Thank you for the sample. I succeeded in reproducing the issue that you are describing and I am going to contact our developers on this matter. I will update you on my progress shortly.
