Silverlight XamGrid
I have this setting for the XamGrid for allowing columns to move
<ig:XamGrid.ColumnMovingSettings> <ig:ColumnMovingSettings AllowColumnMoving="Indicator" /> </ig:XamGrid.ColumnMovingSettings>
The bounded columns i can move between them and cannot move to unbound columns and cannot move Unbound columns
is this expected. I would like to have the unboound columns also move anywhere user wants
Hello Ray,
When you write your response there is an “Options” tab, where you can attach your sample. It should be less than 200 kb, so in order to reduce its size you can remove the bin and obj folders from it.
This is the version i seem to have 11.1.20111.2184 (InfragisticsSL4.Controls.Grids.XamGrid.v11.1)
I dont see that it works. And another issue is
In a grid when i enter data with some calculations. the grid has bound and unbound columns
Data is automatocally entered in another rows as well. I probably has to attach the solution. I dont know how to attach in this post.
Thank you for your post. I have been looking into it and I tested your scenario with the latest service release of 11.1 (11.1.20111.2216) and everything seems to work ok on my side. I can suggest you download the latest service release for 11.1, if you haven’t, by logging to our web site and going to My IG \My Keys and Downloads.
Wanted to tell this happening in version 11.1
