1240
System.NullReferenceException when exporting to PDF
(Using 2011.2 with the latest patches. Exporting to Excel (either 2003, or 2007 works.)
I have a report displaying beautifully in the Silverlight report viewer. Everything seems fine, until I try to export it to PDF. The status window shows it getting to almost 100%, and then it fails with the following:
[Big red X] An error occurred while exporting the report.
Infragistics.Reports.Engine.EngineException: An error occurred while exporting the report. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Documents.Reports.Graphics.VirtualGraphics.set_Font(Font value)
   at Infragistics.Documents.Reports.Report.Text.Text.ComposeUnits(Text text, Composition composition, IGraphics graphics)
   at Infragistics.Documents.Reports.Report.Text.Text.Measure(Composition composition, IGraphics graphics, MeasureMode mode)
   at Infragistics.Documents.Reports.Report.Group.Measure(Composition composition, IGraphics graphics, MeasureMode mode)
   at Infragistics.Documents.Reports.Report.Site.Measure(Composition composition, IGraphics graphics, MeasureMode mode)
   at Infragistics.Documents.Reports.Report.Section.Section.Measure(Projection projection, IGraphics graphics)
   at Infragistics.Documents.Reports.Report.Report.Measure()
   at Infragistics.Documents.Reports.Report.Report.Publish(Stream stream, FileFormat format)
   at Infragistics.Reports.Pdf.PdfDocument.Export(Stream targetStream)
   at Infragistics.Reports.Engine.ReportExporter.ExportInternal(IReportItemVisitor reportItemVisitor, IDocument document, Stream targetStream, ExportCallback callback, IReportItemRendererFactory factory, IReportItemVisitorCancelationProvider cancelationProvider)
   --- End of inner exception stack trace ---
Exception Message:
Stack Trace:
As mentioned, the same report exports correctly to Excel. Can you give me any hints about what to look at in my report definition?
Mike
P.S. When is 2012.1 expected?
