770
Ultraweb Tabs not navigating after deploy to new server
We have an UltraWebTab on a page with several tabs and usercontrols within each tab.  Everything has worked great with this on our older production server, but in moving to a new production environment using Virtual Machines the tabs no longer function correctly.
Clicking on the tab caused absolutely nothing to happen.  We migrated the code from the older server to the new VM server. On the older server it works fine on the new one nothing...
Any help on where to look to resolve this issue would be greatly appreciated.
  • 7566
    Verified Answer
    Hi Ekolluri,
    You need to make sure that the product are successfully deployed with the resource files. You can check this with capturing the network and see if all of them are downloaded correctly. Check if ig_common folder is on the server.
    If you need further assistance, do not hesitate to contact me.
    Sincerely,
    Georgi Sashev
    Developer Support Engineer
    Infragistics, Inc.
