475
Windows Large Fonts
It would appear that if you run any WPF Report on a machine with large fonts set then the report renders very badly in the preview window and when printed.
Steps to reproduce;
With Windows set to normal (100%) font size, create a report with an Image with the container sized to the image, and a Table that stretches across the width of the page.
With normal fonts, the report will look correct when previewed. Now, using the Windows Control Panel adjust the display settings so that Windows is displayed with 125% or larger fonts. When the report is previewed now, the image will be scaled to a size to large to be able to view it all in the container and the table that previously fitted the width of the page is now reduced to about two thirds of the width of the page.
This is a very serious bug. Can you please let me know if there is a work around for this issue and if it is fixed in the upcoming new release?
Thanks.
