How can I put markers on charts of stacked type (stacked column, stacked bar, etc)?
In all the other chart types, I only need to set the Marker for the series, but that doesn't seem to work with Stacked charts.
Thank you in advance.
I have modified the sample I have attached before, so now it has XamWebChart instead of XamDataChart. Also it shows how to display only the bar’s value or the value plus the marker.
Hope this helps you.
Also (I only saw this now), you used a XamDataChart, I'm using a XamWebChart (which is slightly diferent is the properties).
Can you help me with this?
Thank you for your answer and sorry for the late response.
What I meant was not setting the marker as a graphical symbol, but displaying the bar value (the value on the X axis).
How can I do this?
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Please let me know if this helps you or you need further assistance on this matter.
