I have just downloaded the new infragistic 2012.1 for lightswich. How I can upgrade my projects?? I have not find anything in documentation.
Please help!!
thanks
Umesh Sharma
Max,
In order to run our VS 2012 LightSwitch support you should uninstall all prior versions of the product and after that install the latest download of NetAdvantage LightSwitch Extensions (for example: https://ko.infragistics.com/downloads/generate?packageId=00000000-0000-0000-0000-000000003587 )
After that you should be able to upgrade you project to VS 2012 RC.
In case of any questions, please do not hesitate to ask me.
Best regards,
Anatoli
Hi Anatoli,
I upgraded a lightswitch application from NetAdvantage Vol.11.1 to Vol.11.2 (no problem),then from Vol.11.2 to Vol.12.1 (having to add a .NET reference to System.Xml.Linq in Client Generated- References, as I mentionned earlier).Now working fine.
Now when I convert it to VS 2012 RC, I get the following errors:Upon load, Cannot find ~\_Pvt_Extensions\Infragistics.LightSwitch.Extensions\IDE\Reference\Microsoft.LightSwitch.Design.Utilities.dll
Upon execute, Cannot load 'InfragisticsSL5.Controls.Grids.XamPivotGrid.v11.2, Version=11.2.20112.1046,Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'
Does this mean that my application cannot be upgraded to VS 2012 RC?
Hi Max,
This is an issue in the VS LightSwitch IDE. We have logged issue number 685376 in connect. microsoft.com about this long time ago.
In case of any other questions, please let me know.
I tried to upgrade a lightswitch application from NetAdvantage Vol.11.2 to Vol.12.1 folllowing procedure described in blog post.
Executing the upgraded application returned an error in file
~\ClientGenerated\Properties\ApplicationDefinitionLoader.cs
regarding the "using System.Xml.Linq;" and XDocument statements.
I solved this by:
- selecting File view
- Show All files
- Right click on Client Generated- References
- adding a .NET reference to System.Xml.Linq
I am curious as to why this was necessary.
Hi Umesh,
Please take a look at the following blog post: https://ko.infragistics.com/community/blogs/b/mihail_mateev/posts/how-to-upgrade-lightswitch-applications-from-netadvantage-vol-11-1-to-vol-11-2
If you have any futher questions, please let us know.
Anatoli Iliev
