I have a screen that contains a grid and above the grid there are two radio buttons that basically define two different sets of data to view. I'd like to be able to use the TargettypeName property to toggle this view but none of the online links work. The data is not Heirarchical it is one level.
Can someone point me to an example of this functioanlity coded?
we are using 2011 V2 silverlight code
thanks
Hi nickeclipsys,
Will you please post your solution or email to me on pragati.dukale@revalanalytics.com? Hello Infragistic,Actually, I want to expand the row detail (columnlayout) on cell click & even change the data in row detail accordingly. On row expand image click, the data will be different & on cell click expand it will be different. Which event I can use & how can I get this in code behind?
Thanks in advance.Pragati.
never mind figured it out myself
or even One example of how to assing a columnlayout from Code behind.
I can't believe I have been scouring the web for the last hour and not one example (not even in the documentation.) of this is on line.
