I haven't received replied of it yet.
kindly lool into it
we love to move for newer version .but right now we are not in posiotion .
error list is attahced .( more errors are coming up like that )
theses errors are coming on IE9 and other latest browser version
kindly help us to fix it (atleast for IE 9 ) with existing envionment
I mean
how can we fix all these issues to make same controll runing with latest browser and then
we can use new controls ( as you are suggesting )with new functionalities in pur project .
please guide us in details
thanks
For changing the Browser Mode, Go to
Tools --- > "Developer tools."
then look at the lower portion of your browser. click browser mode and then you will different browser version. select IE 7 and Try.
upgrading your project to latest version will take few minutes. Infragistics has a utility to upgrade your existing project.
Are you getting this issue when you publish the code on the server ?
If yes, then try changing the browser mode to IE 7 and check if you are getting this error or not.
If it didn't work then you have to upgrade to new version.
we are using NetAdvantage for .NET 2008 Vol. 1 CLR 2.0
thanks for your quick reply
kindly look into it to help me
i am runing short of time ( hope you understand my position )
what version of infragistic are you using ?
