I use the XamComboEditor :
How can I have a reset button, like the 'SelectedItemsResetButton' of the 'XamMultiColumnComboEditor ' :
Yoann.
Could please send me a sample - I didn't manage to implement this functionality ;/
Thanks in advance!
Hi Petar,
Yes it works thank you.
Hello Yoann,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
I have been looking into this for you and since there is no built-in functionality that provides such a button your only option would be to add a button to the XamComboEditor’s original control template. The templates can be found in the DefaultStyles folder default path: C:\Program Files (x86)\Infragistics\NetAdvantage 2011.2\Silverlight5\Default Styles . The button should simply clear the SelectedItem property.
Please let me know if I can be of any further assistance on the matter.
Sincerely,
Petar, MCTS
Developer Support Engineer II
www.infragistics.com/support
