450
How can i refresh the xamgrid??
i´m trying to refresh a xamgrid dynamically but i can´t.
I have a object wich it is a list of objects and i visualize it with xamgrid.itemSource.
Then i modify or add an object and want to see the new xamgrid.
I tried with xamgrid.itemSource=the modify list but it doesn´t work.
this is my code.
Sub entityHandler(EntityObj As Object)
        Try
            If (EntityObj Is Nothing) Then
                MessageBox.Show("No tiene datos cambiados")
            Else
                MessageBox.Show("Tiene datos cambiados")
                Dim valuePropertyId As Object = EntityObj.GetType().GetProperty(Me.myEntityList.CampoId).GetValue(EntityObj, Nothing)
                'here i add a entity to the list of entities
                If valuePropertyId = 0 Then
                    Me.myEntityList.Entities.Add(EntityObj)
                Else
                'here i search and modify an object
                    For i As Integer = 0 To Me.myEntityList.Entities.Count - 1
                        Dim valueProperty As Object = Me.myEntityList.Entities(i).GetType().GetProperty(Me.myEntityList.CampoId).GetValue(Me.myEntityList.Entities(i), Nothing)
                        If (valueProperty.Equals(valuePropertyId)) Then
                            Me.myEntityList.Entities(i) = EntityObj
                            'here i try to visualize the new list
                            Me.dataGrid.ItemsSource = Me.myEntityList.Entities
                            Exit For
                        Else
                        End If
                    Next
                End If
                'here i try to visualize the new list with the object add
            End If
        Catch ex As Exception
            MessageBox.Show("EntityHandler Error" & ex.Message)
        End Try
     End Sub
I tried to make a function
    Me.LayoutRoot.Children.Clear()
    Me.LayoutRoot.Children.Add(te)
but it doesn´t work because i´m working with a user control and is inside another controls. And it´s going to be use recursively.
Thank you for your support.
Sincerely
David A
