I am trying to persist filters but having no luck.
on cell double click it redirects to a detail page, when navigating back i would like to keep the filters in which the user had prior to leaving the page.
I have this event i am calling on double click:
private void AuditXamGrid_CellDoubleClicked(object sender, Infragistics.Controls.Grids.CellClickedEventArgs e) { var TheCell = AuditXamGrid.ActiveCell; if (TheCell == null) return; var data = TheCell.Row.Data; if (data is GetSummaryAuditResult) { var rowdata = data as GetSummaryAuditResult; PersistenceSettings gridSettings = new PersistenceSettings(); gridSettings.SavePersistenceOptions = PersistenceOption.OnlySpecified;
PropertyNamePersistenceInfo pnpi = new PropertyNamePersistenceInfo(); pnpi.PropertyName = "Columns[].FilterColumnSettings"; pnpi.Options = PropertyNamePersistenceOptions.Contains; gridSettings.PropertySettings.Add(pnpi); MemoryStream ms; ms = PersistenceManager.Save(AuditXamGrid, gridSettings); ViewModel.AppViewModel.AuditFilterSettings = ms.ToArray(); NavigationService.Navigate(new Uri("/AuditDetails?AuditID=" + rowdata.AuditID + "&MatchID=" + rowdata.MatchID + "&PackageID=" + rowdata.PackageID + "&Perner=" + rowdata.Perner, UriKind.Relative)); } } When is gets to the saving the setting i get a stack over flow exception and i just cant get around it.
here is my Grid:
< ig:XamGrid CellDoubleClicked="AuditXamGrid_CellDoubleClicked" FontSize="10" FontFamily="Verdana" Background="#44FFFFFF" HeaderRowHeight="40" x:Name="AuditXamGrid" Height="Auto" RowHeight="25" ItemsSource="{Binding Source={StaticResource ViewModel}, Path=Audits}" AutoGenerateColumns="False" IsAlternateRowsEnabled="True" HorizontalAlignment="Left" VerticalAlignment="Top" Width="Auto"> <ig:XamGrid.FilteringSettings> <ig:FilteringSettings FilteringScope="ColumnLayout" AllowFiltering="FilterRowTop" AllowFilterRow="Top" IsOnCellActiveEditingEnabled="False" IsMouseActionEditingEnabled="SingleClick" /> </ig:XamGrid.FilteringSettings> <!-- Grid Columns --> <ig:XamGrid.Columns> <ig:TextColumn Key="AuditID" IsReadOnly="True" Visibility="Collapsed"/> <ig:TextColumn Key="MatchID" IsReadOnly="True" Visibility="Collapsed"/> <!--<ig:TextColumn Key="PackageID" IsReadOnly="True" Visibility="Collapsed"/>--> <ig:TextColumn Key="PackageID" IsReadOnly="True" HeaderText="Order #"/> <ig:TextColumn Key="BusinessUnit" IsReadOnly="True" HeaderText="Site"/> <ig:TextColumn Key="Perner" IsReadOnly="True" HeaderText="Pernr"/> <ig:TextColumn Key="Name" IsReadOnly="True" HeaderText="Employee Name"/> <ig:TextColumn Key="HireDate" FormatString="{}{0:d}" IsReadOnly="True" HeaderText="Hire Date"/> <ig:TextColumn Key="User" IsReadOnly="True" HeaderText="Requested By"/> <ig:TextColumn Key="UserName" IsReadOnly="True" HeaderText="Requested By Name"/> <ig:TextColumn Key="EmployeeText" IsReadOnly="True" HeaderText="EE Group"/> <ig:TextColumn Key="OverAllScore" IsReadOnly="True" IsSorted="Descending" HeaderText="Overall Score"/> <ig:TextColumn Key="AuditAppUserID" IsReadOnly="True" HeaderText="EAS Agent Working"/> <ig:TextColumn Key="DateOpen" FormatString="{}{0:d}" IsSorted="Descending" IsReadOnly="True" HeaderText="Audit Opened"/> <ig:TextColumn Key="DateClosed" FormatString="{}{0:d}" IsReadOnly="True" HeaderText="Audit Closed"/> </ig:XamGrid.Columns> </ig:XamGrid> Help Please.
ig:XamGrid
FontSize="10"
Height="Auto"
RowHeight="25"
Width="Auto">
</ig:XamGrid>
Ben
Hello Ben,
Thank you for your post. I have been looking into it, but it seems like I am missing something about your scenario, so if this is still an issue for you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you.
UPDATE:
I got it to save to a byt array, its 3megs which seesms big but atleast it works. Unfortunetly I get the same stack overflow exception when trying to load the filter info, I have the load process on the grid loaded event:
private void AuditXamGrid_Loaded(object sender, RoutedEventArgs e) { PersistenceSettings gridSettings = new PersistenceSettings(); //gridSettings.SavePersistenceOptions = PersistenceOption.AllButIgnored; gridSettings.LoadPersistenceOptions = PersistenceOption.AllButIgnored; PropertyNamePersistenceInfo pnpi = new PropertyNamePersistenceInfo(); pnpi.PropertyName = "Columns[].FilterColumnSettings"; pnpi.Options = PropertyNamePersistenceOptions.Contains; gridSettings.PropertySettings.Add(pnpi); AuditXamGrid.FilteringSettings.FilteringScope = FilteringScope.ColumnLayout; if (ViewModel.AppViewModel.AuditFilterSettings != null) { MemoryStream memstream = new MemoryStream(ViewModel.AppViewModel.AuditFilterSettings); PersistenceManager.Load(AuditXamGrid, memstream, gridSettings); } }
I have tried everything i can to get this to work, this issue is under a tight time constraint, please help
