335
XamNumericEditor preserving leading zero after value loaded
Team,
I have a XamNumericEditor which mask as {}{double:-2.0} (a textbox editor for entering 2 digit time value).  However I would like to preserve the leading zero in the XamNumericEditor after value loaded to the field given it is a single digit number.
e.g. I have 2 and after value loaded, would like to see 02
Please advise.  Thanks!
Chris
  • 7305
    Chris,
    I just realized I provided you with WPF answer instead of Silverlight.
    The xamNumericEditor in silverlight does not have a Format property, but you can use xamNumericInput, and the mask and format setting is: Mask="{}{double:-2.0}" Format="00.#".
    I hope this works for you.
    Sam
  • 7305
    Hello Chris,
    You can use the Format property for leading zeros such as:  Format="00.0". I believe the default is "0.00". As a side note, you can also suppress all "insignificant" numbers (zeros), by using pound signs (#) instead of zeros, like Format="#.#".
    Let me know how this worked for you, or if you have any questions.
    Sam
