I work in a big company of software development in Brazil, and we are developing a proof of concept for one of our largest customers, using xamPivotGrid. But we are facing some problems. Could you help us?
The problems are:
1. Is there some limitation in the Silverlight Pivot Grid to use Calculated Metrics? In our proof of concept they don´t appear, just the regular metrics.
2. Is there any limitation on the number of members that can be displayed in each dimension? For larger dimensions we can´t see all members.
3. We also had an error filtering a dimension with many members.
4. Is there a way to format the numeric data that is displayed in the query result?
Thanks a lot!
Thiago Barcellos
Hello Thiago,
This is just a follow up if you require any further assistance.
Response was provided in the following thread: http://community.infragistics.com/forums/p/69686/353258.aspx#353258.
