I work in a big company of software development in Brazil, and we are developing a proof of concept for one of our largest customers, using xamPivotGrid. But we are facing some problems. Could you help us?
The problems are:
1. Is there some limitation in the Silverlight Pivot Grid to use Calculated Metrics? In our proof of concept they don´t appear, just the regular metrics.
2. Is there any limitation on the number of members that can be displayed in each dimension? For larger dimensions we can´t see all members.
3. We also had an error filtering a dimension with many members.
4. Is there a way to format the numeric data that is displayed in the query result?
Thanks a lot!
Thiago Barcellos
Hello Thiago,
This is just a follow up if I can be of any further assistance.
There were few changes since the first time this blog was published. Here I have attached the updated version which works with v12.1 and the latest SR of v11.2. I'm going to investigate what's wrong with the calculated measures and large dimensions as well.
Plamen.
Hello Plamen, thanks for the response.
The source is a XmlaDataSource and i am using adomd.
I am building my solution based on this article: https://ko.infragistics.com/community/blogs/b/engineering/posts/building-a-custom-data-provider-for-xampivotgrid-in-silverlight-using-wcf-and-adomd-net
Thiago
Could you specify which data source is your question about - XmlaDataSource or FlatDataSource? The differences between WPF and Silverlight versions are just platform specific and do not affect the functionality.
Regards.Plamen.
