Is it possible now to save and load IGR reports into/from database reports in v12.1 ?
regards
Many thanks. I'll check that
I could reproduce the problem. The problems happen when executing the application using .NET4. There is a bug in the framework when invoking System.Configuration.ConfigurationManager from the network share, it throws a security exception, and therefore the RuntimeAssemblies are not being taken into account. Here is the explanation of the bug. After installing the provided hotfix the problem is resolved. This problem does not occurs in framework 4.5.
Can you avoid running the application from the network share?
Best,
Leo
Any info ?
Solution ready.
Can you please provide a simple solution that reproduces the problem? For the Uri Provider you can just create a dummy one that displays the messagee and just invokes result.Invoke(null);
