v11.1 does it have ExcelExporter or it is after 11.2 version
I dont see this below. Is it only after 11.2 and ExcelExporter came from 11.2 ver and above?
Perfect
thanks
perfect. thanks
Hello Rayudu,
For exporting sub-totals after row data I have attached an updated sample.
Thanks verified.
Only thing is i want the subtotal after the row data when grouping.
right now. the header comes,. then sum/subtotal comes.
i need: header/row data/sum-subtotals. as the logic for placing the subtotals is inside the header loop. i see subtotals are in the 1st row of each grouped section. need at last row of each grouped section. that is the normal reporting.
For exporting totals and sub-totals when grouping records I have attached an updated sample.
