14517
Add controls to header in Tile Manager
If you want to add controls to the header of the either the entire XamTileManager control or the individual controls, this can be accomplished by changing the styles for the XamTileManager and the TileHeaderPresenter respectively.
For more information on styling the XamTileManager, please see:
 When styling controls, the default styles used can be found in the Default Styles directory for the control you are styling. For the XamTileManager this would be similar to
 C:\Program Files (x86)\Infragistics\NetAdvantage 2012.1\Silverlight\DefaultStyles\TileManager
In this case, since the control is shared between WPF and Silverlight the Styles which I have modified in the attached sample can be found in the generic.shared.xaml file.
Sincerely,
Valerie
Developer Support Engineer
www.infragistics.com/support
BaseTileManager.zip
