140
Null reference in QATMenu.EnsureVisualState
We have a SL application built suing SL4, but currently using IG 11.2 ribbon. We've a couple of error messages appear occasionally. I'm assuming they may be related.
[Arg_NullReferenceException]
Arguments:
   at Infragistics.Controls.Menus.Primitives.QATMenu.EnsureVisualState()
   at Infragistics.Controls.Menus.RibbonToolBaseControl.RibbonToolBaseControl_IsEnabledChanged(Object sender, DependencyPropertyChangedEventArgs e)
   at System.Windows.Controls.Control.OnIsEnabledChanged(Control control, EventArgs args)
   at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags)
Object reference not set to an instance of an object.
   at Infragistics.Controls.Menus.RibbonToolControl.OnRootVisualMouseLeftButtonUp()
   at Infragistics.Controls.Menus.RibbonToolControl.RootVisual_MouseLeftButtonUp(Object sender, MouseButtonEventArgs e)
   at MS.Internal.CoreInvokeHandler.InvokeEventHandler(UInt32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
The behaviour is not easily reproduced. There are no items in the QAT menu, and the user was not ineracting with the QAT menu at the time.
Does anyone have any idea what might cause this?
Thanks.
