hi,when i set datasource to webdropdown,the dropdownitem's text display looks good ,but when i raise client SelectionChanged events,the sender.get_selectedItem().get_value() always return empty, how can i get the selecteditem's value.
//json
var faulData = [{ "SMSFaultCodeID": "1", "FaultCodeName": "error_A"}];
function onDataBind(sender, evntArgs) { evntArgs.set_cancel(true); sender._pi.show(sender); $.ajax({ url: "products", contentType: "text/json; charset=utf-8", dataType: "json", success: function (datatsource, st) { //dataSource = datatsource.data.results; dataSource=faulData ;
sender.set_dataSource(dataSource); sender.dataBind(); sender._pi.hide(sender); }, error: function () { alert("Error with AJAX callback"); } }); }
function onSelectionChanged(sender, evntArgs) { var selectvalue= sender.get_selectedItem().get_value().toString(); }
<ig:WebDropDown ID="myDropDown" runat="server" ClientIDMode="Static" Width="200px" EnableClientRendering="true" DropDownContainerMaxHeight="200" EnableDropDownAsChild="false" AutoPostBackFlags-SelectionChanged="Off" TextField="FaultCodeName" ValueField="SMSFaultCodeID" AutoPostBack="false" ClientEvents-DataBinding="onDataBind" DisplayMode="DropDown"> <ClientEvents SelectionChanged="onSelectionChanged" /> </ig:WebDropDown>
Is there any progress on this post?
This post seems to be in the wrong forum.
It's for the WebDropdown instead of the Webcombo
http://ko.infragistics.com/community/forums/241.aspx
Hi lovedogdog,
I have investigated your issue and, I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 115612. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I will leave this case open and update you with any new information after the review. You can also continue to send updates to this case at any time.
You can view the status of the development issue connected to this case by going to the “Account” tab on our website, hovering to the "My Support Activity" dropdown and selecting the "Development Issues" tab.
Please let me know if you need more information.
