Data is listed in XamPivotDataSelector but data is not visible in XamPivotGrid.
<Grid.Resources><igOlap:XmlaDataSource x:Key="DataSource" ServerUri="http://server/olap/msmdpump.dll" Database="Adventure Works" Cube="Adventure Works" Rows="[Customer].[City]" Columns="[Date].[Date]" Measures="[Measures].[Order Count]" />
</Grid.Resources> <ig:XamPivotGrid HorizontalAlignment="Left" Name="PivotGrid" VerticalAlignment="Top" Grid.ColumnSpan="3" DataSource="{StaticResource DataSource}" Height="425" Width="635" /> <ig:XamPivotDataSelector x:Name="DataSelector" DataSource="{StaticResource DataSource}" HorizontalAlignment="Right" VerticalAlignment="Top" Grid.Column="2" Width="234" Height="413" />
Please suggest what is missing in the above code
As I see you are using 11.1 version. This version is no longer supported. But for this version (11.1) you can use the last Service Release, where the issue is resolved.
M.Yovchev
Thanks for you reply. I look into below screenshot. This is the output I am getting when run the application.
I do not see any missing code above. Looks fine. Can you please attach a simple project or screenshot?
