1930
XamComboEditor template problem on SelectedItem
hi
I'm using a XamComboEditor in a Child window with a custom ItemTemplate. Here is the code:
<ig:XamComboEditor Grid.Row="5" Grid.Column="1" Margin="10,0,0,0" HorizontalAlignment="Left" Name="cboUser" VerticalAlignment="Center" Width="250" DisplayMemberPath="Name" EmptyText="Select..." SelectionChanged=" cboUser_SelectionChanged" TabIndex="6" >
                    <ig:XamComboEditor.ItemTemplate>
                            <DataTemplate>
                                <StackPanel Orientation="Horizontal">
                                    <TextBlock Text="{Binding Path=Name, Mode=OneTime}" />
                                    <TextBlock Text="  " />
                                    <TextBlock Text="{Binding Path=Surname, Mode=OneTime}" />
                                </StackPanel>
                            </DataTemplate>
                        </ig:XamComboEditor.ItemTemplate>
                    </ig:XamComboEditor>
When i click on the arrow and see the DropDown all the Items are shown with Name and Surname as from template.
The problem is that when i select an Item, the selected Item is shown only with "Name" not "Name Surname" as per template.
How can i solve this issue????
Thank you
