Dear Infragistics Support,
Below is the error I am getting (referred to in 1. above) when trying to save the unmodified template XLSX file back to disk:
'summaryBelow' is a duplicate attribute name (at XmlWellFormedWriter.AddAttribute)
The Excel Template file I'm using is attached.
Thanks!
Hello Warren,
The issue has been resolved and the latest service release can be found in My Keys & Downloads page.
For the issue on the image header/footer not being exported I have submitted this as development issue #117361. You can also find case CAS-96103-BB7ZK8 linked at the support activity page: https://ko.infragistics.com/my-account/support-activity.
Unfortunately, no. Our Excel libraries actually share most of their source files, so they differ very little in object model and functionality. This is not supported on any product's Excel library.
OK.
I understand perhaps your ASP.NET NetAdvantage Library has better Excel support? Would you recommend that (for a Server-side approach e.g. Services)?
If so, again, code samples or web links to code samples would be most appreciated for:
Thanks again so much!
-Warren
No, that is currently not supported. With every feature, if we support modifying something, round-trip support is also fully supported. So there are really three levels of support: no support, round-trip support, and full support. Right now, header/footer images have no support.
