I have two dropdownProvider A and B. they are in a same webdatagrid, but two different columns. what I want to do is when A's selection changed, I need to change B's datasource based on A's selected value.
I was googling hours but could n't find an answer. Hope I can get some help from here.
I have the same problem. The link you recommend does not change the datasource so it is difficult to follow. Also if a VB example is available that will be helpful.
I am just following up to see if you have any questions with this matter.
Based on the functionality you described, I would recommend you to review the below forum thread:
<http://ko.infragistics.com/community/forums/p/45774/248098.aspx>
Feel free to update me if you need any further help.
