not sure if this is a limitation or not, did not see it on the limitation page
is this possible?
i get this error:
There was an Error Generating the XML Document
this inner excpetion is
"The type Infragistics.Controls.Grids.XamGridExcelExporter was not expected. Use the XmlInclude attribute to specify types that are not known statically."
tried export & exportasyc, code basically identical to the samples
Please Advise
works after SR update!
SR update was not clean, had to drop all refs and re add
Hello spicish2222,
When installing the latest service should automatically apply to an existing project and setting Specific Version of the references to false.
will installing the SR effect projects already in flight? or we we have to drop and re add all references?
There is a service release available that was in resolved in 11.2 that provides this fix when exporting. The latest service release version can be found in My Keys & Downloads page: https://ko.infragistics.com/my-account/keys-and-downloads/.
