780
Error using the JSON JavaScriptSerializer
We are getting the following error when we are grouping by one column using UltraWebGrid v 11.2 framework 4.0
“Error during serialization or deserialization using the JSON JavaScriptSerializer. The length of the string exceeds the value set on the maxJsonLength property.”
We set the maxJsonLength property to a large value in the Web.config file and we get the same error.
We have just 295 records. We are using Virtual Scrolling.
.DisplayLayout.LoadOnDemand = Infragistics.WebUI.UltraWebGrid.LoadOnDemand.Xml
.DisplayLayout.XmlLoadOnDemandType = Infragistics.WebUI.UltraWebGrid.XmlLoadOnDemandType.Virtual
When we group by a column we change these properties (I also tried to comment this two lines and I got the same error):
.DisplayLayout.LoadOnDemand = Infragistics.WebUI.UltraWebGrid.LoadOnDemand.NotSet
.DisplayLayout.XmlLoadOnDemandType = Infragistics.WebUI.UltraWebGrid.XmlLoadOnDemandType.Synchronous
How can we solve this problem?
Thanks in advance.
