260
xamContextMenu and MVVM on a XamDataTree
I am using a SL XamDataTree and wish to bind a context menu to a command in my ViewModel (MVVM).
The tree is defined as follows:
<ig:XamDataTree  x:Name="xamTree"
                                         AllowDrop="True"
                                        IsDropTarget="True"
                                         AllowDragDropCopy="False"
                                        Grid.Row="0"
                                        ItemsSource="{Binding RootFolderContactsNode.SubItemsSorted}"
                                        MaxHeight="550"
                                        NodeDragDrop="xamTree_NodeDragDrop"
                                        Background="Transparent">
                            <ig:XamDataTree.GlobalNodeLayouts>
                                <ig:NodeLayout x:Name="NL"
                                               Key="SubItemsSorted"
                                               DisplayMemberPath="Name"
                                               TargetTypeName="FolderContactTreeNode"
                                               IsDraggable="True"
                                               IsDropTarget="True">
                                    <ig:NodeLayout.ItemTemplate>
                                        <DataTemplate>
                                            <StackPanel>
                                               <ig:ContextMenuService.Manager>
                                                    <ig:ContextMenuManager OpenMode="None">
                                                        <ig:ContextMenuManager.ContextMenu>
                                                            <ig:XamContextMenu Name="cmuFolder"
        <ig:XamMenuItem Header="Edit">
        <ig:Commanding.Command>
        <ig:XamContextMenuCommandSource EventName="Click"
        Command="{Binding DataContext.CommandEditFolderOrContact, ElementName=LayoutRoot}"
        Parameter="{Binding}"/>
        </ig:Commanding.Command>
        </ig:XamMenuItem>
                                                            </ig:XamContextMenu>
                                                        </ig:ContextMenuManager.ContextMenu>
                                                    </ig:ContextMenuManager>
                                                </ig:ContextMenuService.Manager>
                                                <StackPanel Orientation="Horizontal">
                                                    <Image Source="{Binding Data.Image}" Width="12" Height="12"/>
                                                    <TextBlock Text="{Binding Data.Name}" Margin="2.5,0,0,0"/>
                                                </StackPanel>
                                            </StackPanel>
                                        </DataTemplate>
                                    </ig:NodeLayout.ItemTemplate>
                                </ig:NodeLayout>
                            </ig:XamDataTree.GlobalNodeLayouts>
                        </ig:XamDataTree>
I keep getting an unhandled exception because of the Command parameter in the <ig:XamContextMenuCommandSource/> element.  'Command' does not show up in intellisense, but is in the documentation (http://help.infragistics.com/Help/NetAdvantage/Silverlight/2012.1/CLR4.0/html/InfragisticsSL5.Controls.Menus.XamMenu.v12.1~Infragistics.Controls.Menus.XamContextMenuCommandSource_members.html). Any help in how to use Commanding correctly on a ContextMenu in a xamDataTree would be appreciated.
Thank you,
Bill
