845
What are the events that fire when a XamGrid is loaded?
We have a XamGrid that is displaying data from a PagedCollectionView that allows filtering. We have had to subclass the XamGrid and add code to get this to work as we would like.
When the XamGrid is loaded with a filter set the total number of displayed items isn't set to the correct value even though the data is filtered correctly. I'm trying to trace through the events to track down the problem and have found that the "Filtering" event is fired before the "Loaded" event.
Ideally I would like a "Loading" event that gets fired when the load operation starts so I can set our code into the correct mode, but there isn't such an event.
What is the order of events that fire when a XamGrid is loaded?
We are using v11.2 on Silverlight 5.
