Need to know if the component is able to show paging component across the width of a xamgrid, since we only display on the columns are not grouped in the same, the rest does not come out correctly. We have seen an open line on this issue in this direction is this bug http://ko.infragistics.com/community/forums/t/46318.aspx already solved?
Hi rgherrero,
Do you still require assistance with this?
I'm currently looking into this for you and I have a few questions. Do you mean how the gray part behind the paging component doesn't stretch across the entire width of the grid? It looks like you have some style or theme set on the grid. Can you provide more information about this or provide the style that you are using?
