I'm trying to achieve a feature where the user cannot move any of the slider thumbs over another. I have 2 to 3 thumbs in my slider and each one is in Lock interaction mode. This prevents pushing the thumbs with another thumb but I want to expand this functionality so that the two thumbs cannot get the same value.
I've been trying to achieve this by using the ThumbValueChanged -event but it seems the e.Cancel = true doesn't do anything?
Is there a way to get the slider working in a way I want it to? Thanks for the help already.
Hello Antti,
Thank you for your post. I have been researching your issue. I have created a small sample for you. Please find the attached sample and do not hesitate to contact us if I misunderstood your requirements.
Thanks for the sample but it doesn't seem to work. I can see from the code that you tried pretty much the same than what I did. If the sample works for you, then is this a bug in the version I'm using? I'm still using 11.2.20112.74 so can you check with that version to see if you can get it working or not? Thanks in advance.
Thank you for your patience. I have modified the previous sample for you. Please find the attached sample and do not hesitate to contact us if you have any further questions.
I still cannot get it working. The labels you added state that the values are indeed different but the actual thumbs remain at the same location. This is also the behavior I'm getting. I've attached a screenshot of the situation, if it helps any.
After researching this functionality, it has been determine as a new Product Idea. I have sent your Product Idea directly to our product management team. Our product team chooses new Product Ideas for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested ideas, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your idea is chosen for development, you will be notified at that time. Your reference number for this Product Idea is PI12080090.
If you would like to follow up on your Product Idea at a later point, you may contact Developer Support management via email. Please include the reference number of your Product Idea in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
Ok. Good to know that. Thanks for taking this functionality under consideration in the future.
