95
Select 'current row' at databind
Hello
I am trying to use a WebCombo as a record navigation tool because it allows better data display than a standard DropDown. The previous page has a grid of records. When selected the full record details are displayed on the next page (with the WebCombo). Rather than have to return to the previous page I want the user to be able to select the next record from the WebCombo. It works fine, however I want to pre-position the WebCombo at whatever record the page is initially loaded at as it would look more professional plus require less scrolling if the next record is reasonably close to the current record.
 The code I have tried is as follows - using an arbitary value for the test:
wcProcess.DataSource = lNav
wcProcess.DataBind()
wcProcess.SelectedIndex = wcProcess.FindByValue("CRM0020").Row.Index
The error I receive is:
System.NullReferenceException was unhandled by user code
  Message="Object reference not set to an instance of an object."
Can anyone help??
Regards
James
