165
Tab pane open, close, open problem
I'm having an issue, wherein after I close the last tab in the dock manager, attempting to create/open a new one doesn't appear to be working.
I've attached a sample project that illustrates the problem.  After you have started the project, click the "Add Control" button.  This Will cause a new tab to be created, the content of which is the custom control.
Then close the tab by clicking the small "X" on the tab, so that the dock manager is empty again.
Finally, click the "Add Control" button again, and note that no new tab appears.
Am I missing something obvious?
Further to that, restart the project and click "Add Control" to create a tab.  Then double-click on the tab to cause the tab window to float.  Then click on the "Add Control" button again, and note that no new tab appears.
Something else obvious that I'm missing?
I'm using the SL4 11.2 versions of the controls.
Thanks!
SilverlightApplicationIssue1.zip
