1455
export fails when grouped
i have a grid that exports fine as long as it is not grouped.  the exporter and the code behind are using essentially the code from here
http://help.infragistics.com/Help/NetAdvantage/Silverlight/2011.2/CLR4.0/html/xamGrid_Asynchronous_Export_to_Excel.html
when i allow grouping the grid will not export.  it also fails to through the exception in the catch.  if i debug and step through i can capture it
mesage
"There was an error generating the XML document."
Innerexception
"Exception of type 'System.OutOfMemoryException' was thrown."
i do not understand why this is occuring, it is not in the known issues for export
any help would be apprciated
