500
Clear Multi-Select WebDropDown Client Side
I have  a webdropdown with enable multiple selection  set to true. I want to clear the checked chekboxes within the drop down on rthe client side using Javascript. I referred to http://community.infragistics.com/forums/p/30177/161244.aspx#161244 which shows how to do this for a single selection dropdown.
how do I clear the multi-select dropdown and reset the current value to say "select"?
This is the code from the other post for single selectio which does not work for the multi-select.
        function clearSelection() {
            var dropDown = $find("WebDropDown1");
            var item = dropDown.get_items().getItem(dropDown.get_selectedItemIndex());
            if (item != null) {
                item.unselect();
                item.inactivate();
                // optionally, clear input text
                // dropDown.set_currentValue("",true);
            return false;
Thank you.
