Good afternoon. Previously worked on Windows XP, everything worked fine. Switched to Windows 7x32, there was a problem during installation InfragisticsSL4.Controls.Menus.XamRibbon.v11.1. Create an application for Silverlight4, using other components InfragisticsSL4, all is well. Adds a reference to an error compiling InfragisticsSL4.Controls.Menus.XamRibbon.v11.1 " Could not load file or assembly 'InfragisticsSL4.v11.1, Version = 11.1.20111.2266, Culture = neutral, PublicKeyToken = 7dd5c3163f2cd0cb' or one of its dependencies ". What could be the problem?
Like budy up, thanks :)
Thank you for your help. Problem solved re-installing Windows 7 Pro -> Windows 7 Max. Have a good day.
Good afternoon. Thank you for your help. Win7x64 on me too it works. Try reinstalling Net Framework and clean up the registry.
Hmm, weird. Everything seems fine to me. I'm running out of ideas.. I tried running your project and had no issues whatsoever with the exact same build you're using (2266). I'm running it on Win7 x64 though.
I'll look into it further and will let you know if I find anything.
Image And Solution
