325
How to set initial Display Text?
this link(http://ko.infragistics.com/community/blogs/devin_rader/archive/2011/06/01/using-behaviors-to-synchronize-selected-items-of-infragistics-silverlight-controls-to-a-viewmodel.aspx) shows how to synchronize multipleSelection from the UI side.
but if i initialize the SelectedCustomers property by adding two customer, run it, the UI side doesn't show the information.
now i can get the multipleSelection itmes' value by this following way,
1. define the SelectedItemsValues
        public static readonly DependencyProperty SelectedItemsValuesProperty = DependencyProperty.Register("SelectedItemsValues", typeof(List), typeof(XamComboEditorSelectedItemsBehavior), new PropertyMetadata(OnSelectedItemsPropertyChanged));
        public List SelectedItemsValues
2. in the  Combobox.SelectedItems.CollectionChanged event, foreach the items to get the value what i want. each item is ICityDimension type.
            UnsubscribeFromEvents();
            Transfer(Combobox.SelectedItems, SelectedItems as IList);
            List results= new List();
            foreach (object tmp in Combobox.SelectedItems)
                convert.Add(((ICityDimension)val).Description);
            SelectedItemsValues = convert;
            SubscribeToEvents();
anybody can tell me how to set the initial Display Text when the SelectedItems is from the DB side instead of user's UI selection,  or which property/evnet  related to Display the text? if possible, can give a demo(MVVM pattern)?thanks in advance.
my behavior class is as follows:::::
 public class XamComboEditorSelectedItemsBehavior : Behavior
        private XamComboEditor Combobox
            get
                return AssociatedObject as XamComboEditor;
        public static readonly DependencyProperty SelectedItemsProperty = DependencyProperty.Register("SelectedItems", typeof(INotifyCollectionChanged), typeof(XamComboEditorSelectedItemsBehavior), new PropertyMetadata(OnSelectedItemsPropertyChanged));
        public INotifyCollectionChanged SelectedItems
            get { return (INotifyCollectionChanged)GetValue(SelectedItemsProperty); }
            set { SetValue(SelectedItemsProperty, value); }
            get { return (List)this.GetValue(SelectedItemsValuesProperty); }
            set { this.SetValue(SelectedItemsValuesProperty, value); }
        private static void OnSelectedItemsPropertyChanged(DependencyObject target, DependencyPropertyChangedEventArgs args)
            var collection = args.NewValue as INotifyCollectionChanged;
            if (collection != null)
                collection.CollectionChanged += ((XamComboEditorSelectedItemsBehavior)target).ContextSelectedItems_CollectionChanged;
        protected override void OnAttached()
            base.OnAttached();
            Combobox.SelectedItems.CollectionChanged += new NotifyCollectionChangedEventHandler(SelectedItems_CollectionChanged);
            //Combobox.Loaded += new RoutedEventHandler(Combobox_Loaded);
        void Combobox_Loaded(object sender, RoutedEventArgs e)
            throw new NotImplementedException();
        void ContextSelectedItems_CollectionChanged(object sender, NotifyCollectionChangedEventArgs e)
            Transfer(SelectedItems as IList, Combobox.SelectedItems);
        void SelectedItems_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
            List convert = new List();
                convert.Add(((ICityDimension)tmp).Description);
        private void SubscribeToEvents()
            Combobox.SelectedItems.CollectionChanged += SelectedItems_CollectionChanged;
            if (SelectedItems != null)
                SelectedItems.CollectionChanged += ContextSelectedItems_CollectionChanged;
        private void UnsubscribeFromEvents()
            Combobox.SelectedItems.CollectionChanged -= SelectedItems_CollectionChanged;
                SelectedItems.CollectionChanged -= ContextSelectedItems_CollectionChanged;
        public static void Transfer(IList source, IList target)
            if (source == null || target == null)
                return;
            target.Clear();
            foreach (var tmp in source)
                target.Add(tmp);
