Hello Infragistics Community,
I want to change same Properties in a Report at Runteim.
At Example the Background Color of a label.
It is possible to do this?
Best regards,
Johannes
Hi Johannes,
It's possible to make the value of some properties change at runtime depending on the data values. For example you can make the background color of a label depend on the datasource, or a parameter, in order to change it dinamically.
It's explained in more detail in the topic "How to Use Conditional Formatting":
http://ko.infragistics.com/help/topic/73608305-6896-4A19-A2F2-B1C770ACF0A7
Do you think this is what you are looking for?
Luis
