Hi
I have an issue with removing XamTile from XamTileManager they keep alive in memory, I'm using ANTS Memory Profiler,
attached is screen shot of the ANTS Profiler app
Hi Stefan
Its good to hear about this update, I grateful for your effort, our product still on beta with Trial Infragistic Component, we will surely take this update after we move to licenced verion of component..
Xusan.
Hello Xusan,
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
I have logged this with development under ID: 121514 and I have also created a support ticket on your behalf: CAS-100490-T0P1X9 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Thanks for your reply, sure I'm attaching a sample where you can reproduce this issue, actually what I'm seeing is that when we close XamTile it removes corresponding data item from our ViewModel collection but XamTile itself stays alive in memory seems like XamTileManager just make it visibility collapsed but doesn't remove it from visualtree as well as clears all referance to it,
Currently I found 2 strong references to XamTile after it was removed
1. Tile being stored in TileAreaPanel in Children collection even after it was removed.....
2. TileLayoutManager keeps reference to XamTile even after tile was removed.....
Thank you for your post. I have been looking into it, but without a sample, where the issue is reproduced, I am not able to conclude what could be the reason for such behavior, so if you could send me the sample, which causes you issue, I would be able to investigate this further for you.
