980
The referenced component could not be found
Hi, The few DLL's I use and have referenced in my project are causing compiler warnings when the project solution is opened on another machine (from TFS). These references are added to the c# Solution from an External folder, who is placed within the TFS project structure, where I have copied them from their original path location (ProgramFiles\Infragistics\...) Warning 1 The referenced component 'InfragisticsSL5.v12.1' could not be found. Warning 2 The referenced component 'InfragisticsSL5.Documents.Excel.v12.1' could not be found. Warning 3 The referenced component 'InfragisticsSL5.Documents.Core.v12.1' could not be found. Warning 4 The referenced component 'InfragisticsSL5.DataVisualization.v12.1' could not be found. Warning 5 The referenced component 'InfragisticsSL5.Controls.Menus.XamTree.v12.1' could not be found. Warning 6 The referenced component 'InfragisticsSL5.Controls.Menus.XamOutlookBar.v12.1' could not be found. Warning 7 The referenced component 'InfragisticsSL5.Controls.Menus.XamMenu.v12.1' could not be found. Warning 8 The referenced component 'InfragisticsSL5.Controls.Interactions.XamDialogWindow.v12.1' could not be found. Warning 9 The referenced component 'InfragisticsSL5.Controls.Grids.XamGrid.v12.1' could not be found. Warning 10 The referenced component 'InfragisticsSL5.Controls.Charts.XamWebChart.v12.1' could not be found. Warning 11 The referenced component 'InfragisticsSL5.Controls.Charts.XamDataChart.v12.1' could not be found.
